I would like to know the internal pull-up resistor on RESET# and WP# for the S25FS512S and S70FS01GS (1.8V) family.
Previous your answer of KBA218745, I know it was made "pull-up leakage " circuit for FL-S (3V) family.
Is it same for the internal circuit of FS-S family?
If yes,
What is the leakage current in the pull-up leakage circuit of S25FS512S and S70FS01GS (1.8v) family?
Thank you & Regards,
Hello Masaya,
In addition to my previous response, the input leakage current is ~2uA, (-40C to 85C), as detailed on page 24
within the S25FS512S datasheet. Therefore the internal "pull-up circuitry" is ~1Mohm.
Thank you and regards,
Albert
Cypress Applications Support
Hello Masaya,
Thank you for contacting Cypress community forum. Currently we are reviewing your issue and will get back to you as soon as we find the resolution.
Have a wonderful day
Bushra
Hello Masaya,
Yes, the "pull-up leaker" circuit also exists within the S25FS512S. However, in order to calculate the approximate
pull-up circuit resistance specifically for the S25FS512S, please do keep in mind that the maximum VCC is 2.0V.
Albert
Hello Masaya,
Albert
