Nor Flash Forum Discussions
Alectronic
Hi ,
I'm using the flash chips of Cypress  S25FL256SAGBHI300 , and the WIP bit in the Status_register_1 indicates always a 1 and never 0 even after a power ON/OFF/ON .
Is it possible to clear that bit ?
Thanks for your help.
Alex
Yuvraj
250 sign-ins 50 solutions authored 100 replies posted
Thank you for contacting Infineon Technologies.
If you want to clear (Set, it as 0) WIP bit in the Status_register_1 you need to use Write Disable (WRDI 04h).
Please refer Write Disable (WRDI) command sequence from data sheet of page 84.
Link to download data sheet https://www.infineon.com/dgdl/Infineon-S25FL128SS25FL256S_128_Mb_(16_MB)256_Mb_(32_MB)_3.0V_SPI_Flas...
If you have additional quires, please let me know, I am happy to solve your doubts.
Yuvraj
Hi Yuvraj ,
Thanks for your reply , but I 'm not sure your solution will solve the issue.
The WRDI commande sets the WEL bit to a '0'   not the WIP ( Write in progress) bit . It is written a little further in the text that the WRDI command is ignored ... while WIP bit = '1' .
My issue is that the WIP bit is always set to '1' even after a power on and at the first status register reading .
Alex
Yuvraj
Hi Alex,
Sorry for my previous reply, I got confused the WEL bit with the WIP bit.
From the data sheet you can see WIP bit is Volatile, Read-only, so we can't write to this bit.
This bit's status is set by flash itself.
We want to know, are you getting WIP bit in the Status_register_1 indicates always a 1 in a new device or already used devices.
Which are the operations being performing before checking status register.
Please make sure you are following Power-up and power-down as per data sheet from page 33 of the data sheet.
Yuvraj
Hi Yuvraj ,
Thanks for your reply .
The WIP indicates always a 1 in this already device .
The WIP indicates 0 in a new device.
After power on , a Write Enable command(WREN)  is performing before checking the status register_1 .
Regarding Power-up and power-down all is ok and the conditions are meet.
I suppose that the device is locked in a ''Write In Progrees'' state and we can't unlock it.
Regards.
Alex
Yuvraj
I am thinking. you might have corrupted the FLASH device.
Corruption might happen due to abrupt power during embedded operation such as programming or erasing.
Please avoid sudden/abrupt power down during any operation in your application for your new devices.
Yuvraj
