For S25FL 128L how to clear the WIP bit ?
Alectronic
Hi ,
I'm using the flash chips of Cypress  S25FL256SAGBHI300 , and the WIP bit in the Status_register_1 indicates always a 1 and never 0 even after a power ON/OFF/ON .
Is it possible to clear that bit ?
Thanks for your help.
Alex
Yuvraj
250 replies posted 25 likes received 100 solutions authored
Hi Alex,
Sorry for my previous reply, I got confused the WEL bit with the WIP bit.
From the data sheet you can see WIP bit is Volatile, Read-only, so we can't write to this bit.
This bit's status is set by flash itself.
We want to know, are you getting WIP bit in the Status_register_1 indicates always a 1 in a new device or already used devices.
Which are the operations being performing before checking status register.
Please make sure you are following Power-up and power-down as per data sheet from page 33 of the data sheet.
Yuvraj
Yuvraj
Thank you for contacting Infineon Technologies.
If you want to clear (Set, it as 0) WIP bit in the Status_register_1 you need to use Write Disable (WRDI 04h).
Please refer Write Disable (WRDI) command sequence from data sheet of page 84.
Link to download data sheet https://www.infineon.com/dgdl/Infineon-S25FL128SS25FL256S_128_Mb_(16_MB)256_Mb_(32_MB)_3.0V_SPI_Flas...
If you have additional quires, please let me know, I am happy to solve your doubts.
Yuvraj
Hi Yuvraj ,
Thanks for your reply , but I 'm not sure your solution will solve the issue.
The WRDI commande sets the WEL bit to a '0'   not the WIP ( Write in progress) bit . It is written a little further in the text that the WRDI command is ignored ... while WIP bit = '1' .
My issue is that the WIP bit is always set to '1' even after a power on and at the first status register reading .
Alex
Yuvraj
Hi Alex,
Yuvraj
Hi Yuvraj ,
Thanks for your reply .
The WIP indicates always a 1 in this already device .
The WIP indicates 0 in a new device.
After power on , a Write Enable command(WREN)  is performing before checking the status register_1 .
Regarding Power-up and power-down all is ok and the conditions are meet.
I suppose that the device is locked in a ''Write In Progrees'' state and we can't unlock it.
Regards.
Alex
Yuvraj
I am thinking. you might have corrupted the FLASH device.
Corruption might happen due to abrupt power during embedded operation such as programming or erasing.
Please avoid sudden/abrupt power down during any operation in your application for your new devices.
Yuvraj
