I have downloaded SW from below link, facing issue while installing drivers I got below error.
Flash Explorer for FSK Programming Tool (cypress.com)
I am using below OS.
USB Superspeed Peripherals
- usb
One of the reasons for this error is that, Windows does not allow you to install unsigned drivers. Please try installing the flash explorer software after configuring Windows to allow installation of unsigned drivers. You can follow the instructions in the attached document.
Also, FSK-PUP programming kit is currently in obsoleted state. Do you already have the FSK-PUP programming kit with you?
Thanks and Regards,
Sudheesh
Hi Sudheesh,
I have tried this steps it did not help getting same issue.
Is there any other option to fix this?
We have Spansion reader kit.
Harish.
