First of all thank you for your help.
The S29GL512 has more than one problem I can not understand.
1: Low or High states of the WE CE OE pins in writing.
2: In the case of reading again the states of the 1 st posting pins.
3: To start the Write and Read routines, the appropriate CE CE OE pin is adequate.
0x0555, 0x0AAA in initialization routines if there is not enough I have a shortage of how to sort the initialization codes.
Parallel NOR
I hope you are asking about the timing details and command sequence for program and read operation. Please correct me if I am wrong.
Timing details and command sequence are available in our datasheet,
S29GL512T: http://www.cypress.com/file/218336/download
S29GL512S: http://www.cypress.com/file/177976/download
Thanks and Regards,
Sudheesh
