emhoc_4198446
FM28V020-TG; TSOP 32;  datasheet shows pin orientation either on top left corner or on the middle, but on physical parts on right top corner. Please confirm correct pin orientation for these parts.
thank you,
Emelita
Hi Emelita,
The half circle on the left center of the package (TSOP I, 32 pin) is the correct orientation identification. You can ignore the circle on top right corner of the package. Also, the correct package drawing for 32-TSOP I is given on page 18 of the datasheet, "Figure 16. 32-pin TSOP I Package Outline, 001-91156". Datasheet: https://www.cypress.com/file/136591/download
Thanks and Regards,
Sudheesh
SudheeshK
250 sign-ins First question asked 750 replies posted
Hi Emelita,
For a better understanding of your query, could you please attach a photo of top markings of the FM28V020-TG (With orientation ID on top right corner)?
Thanks and Regards,
Sudheesh
Thank you for your reply Sudheeshk_26, please see below
Hi Emelita,
Thanks and Regards,
Sudheesh
Thank you so much Sudheeshk for your help and confirmation for these part.
Thank you,
EMELITA HO
Supervisor, Electronic Inspection
<http://www.smithweb.com/>
T: 852-2-854-3232<tel:852-2-854-3232>
M: 97838392<tel:97838392>
E: eho@nfsmithfe.com.hk<mailto:eho@nfsmithfe.com.hk>
www.smithweb.com<http://www.smithweb.com>
1/F, Continental Electric Industrial Building, 17 Wang Chiu Road, Kowloon Bay, Kowloon | , Hong Kong
