Hi Everyone,
We are using parallel NOR flash(S29JL032J) in our custom board. I have gone through the datasheet of this chip. Need to develop driver for this chip. Any example programs on this will be greatly helpful. Tried searching the web, but no luck.
Any references?
ThankYou!!
Hi @saiVamsi ,
You can refer to the Low Level drivers shared. I am not aware of what microcontroller you are using with Flash. You can use the document in the LLD files to modify it according to the board that you are using. Please let us know if you have any doubts in implementing that.
Ronak
Hi @saiVamsi ,
You can refer to our Low Level Driver for NOR Flash. Also, do you want to any specific example to perform a set of operations on Flash?
Ronak
Hi @Ronak ,
Thanks for the reply. Yes, I need example programs to perform read, write and erase operations on Flash.
Can you please share them?
Hi @saiVamsi ,
Ronak
