I need to interface with the S70GL02GS flash. I needed the sequence of commands for ersa and program which I am not ale to find in the datasheet. Could you pleasepoint me to a document or provide an example of interfacing with the flash for programming/erasing. I would appreciate both multiword and word by word programming examples
Sachin
Hi Sachin,
Thank you for contacting Cypress Semiconductor.
S70GL02GS is a dual die stack of two S29GL01GS die. You will find the detailed command set and sequence in the datasheet for S29GL01GS part here.
Please let me know if you have any more queries.
Apurva
Hi Sachin,
Apurva
Apurva,
Thank you very much for the quick response.
Now that I will try to interface with the EA commands, I might face certain issues for which i might raise more issues in a seperate thread. Thanks in advance for the support
Sachin
