We are using S29GL064S NOR FLASH of Model 03. We are using 16 bit address mode. As per datasheet, Block 127 to 134 are 8K/4K. I wanted to erase, read and write the this 8/4K blocks. Read and write operation are working fine in this block. But when i give erase command, its erasing complete 127 to 134 block instead of erasing only 127th Block.
Can you help me is this the expected behavior or missing something?
Thanks in advance.
Hello Utthunga,
Just for our clarification, SA127 is the only sector address you wish to erase. Is this correct?
If yes, selecting any address within the 16-bit address range (3F8000h–3F8FFFh) will select SA127
only for sector erase.
Please ensure that only one sector address (within the 16-bit address range 3F8000h–3F8FFFh) is entered.
After the sector address (for SA127) has been entered, there is a 50uS time-out period. After the 50uS time-out
period has expired, the sector erase operation will initiate.
Pg. 18:
Pg. 42:
Thank you and regards,
Albert
Cypress Semiconductor Corp.
An Infineon Technology Company.
Hi Albert,
We tried in same way you explained above, but the result is same. i. e when I wanted to erase, read and write only one 8/4K block, read and write operation are working fine in this block. But when i give erase command, its erasing complete 127 to 134 block instead of erasing only 127th Block. Waiting for your response. Thanks in advance.
Hello Utthunga,
This is certainly puzzling. How many S29GL064S devices have encountered this same issue? There may be the possibility that the S29GL064S may be mis-labeled as model 03, but may actually be a model 01, 02, etc, as these models have uniform sector architecture. As an experiment, please program, read and erase SA131, or any other sector between SA128 and SA134. if the result is the same (as previously with SA127), this may be a model mis-labeling issue, as models 01, 02, V1 and V2 have SA127 through SA134 (address range=3F8000h–3FFFFFh)
For model 03, it has Top Boot sector architecture. Therefore, SA127 has an address = 3F8000h–3F8FFFh range. At your earliest convenience, please provide the top side photo of the package marking/label, as well as provide information from which third-party vendor the S29GL064S flash memory devices were purchased. Hopefully, these devices have not been re-marked or re-labeled.
Albert
An Infineon Technologies Company.
Hello Utthunga,
Albert
Hello Utthunga,
< 2nd Notice >
Albert
Hello Utthunga,
< 3rd Notice >
Albert
Hello Utthunga,
Happy New Year!
As an experiment, please program random data in both sector SA130 (3FB000h–3FBFFFh)
and SA133 (3FE000h–3FEFFFh). After successful program of both sectors SA130 and SA133,
initiate a sector erase operation on sector SA133 only. Check if the randomly programmed data
in sector SA130 has been inadvertently erased.
Please let us know of your findings/results with regards to SA130.
Albert
