Migrating from MX25L25645G to S25FL064L.
Used with renesas RA6M5 no access to S25FL064L but MX25L25645G is OK.
The command set looks to be equal.
Any hints to make it work ?
BR
PrebenG
- s25fl064
Thank you for contacting Infineon Technologies.
Please find the following application notes which will help you Migrating to S25FL-L Serial NOR Flash Macronix M25L-F Devices : https://www.infineon.com/dgdl/Infineon-AN202471_Migrating_to_Infineon_S25FLL_Serial_NOR_Flash_from_W...
Hope it can help.
Yuvraj
Hope it can help.
Yuvraj
