Dec 03, 2019
11:40 PM
Dec 03, 2019
11:40 PM
Dear
I'm using NOR flash S29JL064H.
Does RY/BY# work if trying to program the same address twice without erase?
In normal case RY/BY# will change from low to high when the program completed
but I'm not sure about the case of programming twice...
Labels
Parallel NOR
12:26 AM
Dec 04, 2019
12:26 AM
Yes, RY/BY# pin will work, when you try to program the same address without erase. Are you facing any issues with RY/BY# pin behavior after a re-program operation.
Please note, it is not recommended to re-program a memory location without erase. Could you please clarify, why you want to perform re-program operation without erase?
Thanks and Regards,
Sudheesh
