Difference between S29PL032J70BFI120 and S29PL032J70BFI070
GrCa_1363456
Level 6
Level 6
50 likes received Beta tester First comment on KBA
What is the difference between S29PL032J70BFI120 and S29PL032J70BFI070?
S29PL032J70BFI120 is reported to be Obsolete with NO replacement per PTN181204 or PTN181204A.
A quick glance at old Spansion datasheets appears to show Spansion's S29PL032J70BFI120 is equivalent to Cypress' S29PL032J70BFI070 other than the Max Sector Erase Time increased from 2 seconds to 5 seconds. The typical Sector Erase Time for both parts is listed as 0.5 seconds.
The web page for S29PL032J70BFI120 points to data sheet revision F that lists S29PL032J70BFI070 but does not include S29PL032J70BFI120.
Valid suffixes in data sheet revision F appear to be 04x through 10x.
The previous Spansion S29PLxxxJ datasheet shows options 00x through 03x and 12x through 13x.
It appears the mapping is:
From 00x to 04x (3.0V VIO, 80-ball 8 x 11 mm FBGA (VBG080))
From 01x to 05x (1.8V VIO, 80-ball 8 x 11 mm FBGA (VBG080))
From 02x to 06x (3.0V VIO, 64-ball 8 x 11.6 mm FBGA (VBH064))
Suffix 03x was deprecated (1.8V VIO, 64-ball 8 x 11.6 mm FBGA (VBH064))
From 12x to 07x (3.0V VIO, 48-ball 8 x 6 mm FBGA (VBK048))
From 13x to 10x (3.0V VIO, 56-ball 7 x 9 mm FBGA (TBD))
Suffix 08x and 09x were added (3.0 and 1.8 VIO, 56-pin 20 x 14 mm TSOP (TS056))
Greg
Hello Greg,
Thank you for contacting Cypress Semiconductor.
As you had previously pointed out, the migration path from model 12x is to model 07x.  The  package type (8 x 6 mm FBGA (VBK048)
package, is correct.
Please find attached the S29PL-J datasheet (to include model 12).
Albert
Cypress Semiconductor Corp.
An Infineon Technologies Company
AlbertB_56
500 replies posted 50 likes received 250 replies posted
Hello Greg,
Albert
Hello Greg,
Albert
