The output of RDID command (JEDEC 9Fh) is different between S25FL064L and S25FL064P.
S25FL064L RDID command (JEDEC 9Fh)
Byte Address, Data, Description
00h 01h Manufacturer
01h 60h Device ID – Memory Interface Type
02h 17h Device ID – Density and Features
03h Undefined - Reserved for future use
S25FL064P RDID command(JEDEC 9Fh)
01h 02h Device ID
02h 16h Device ID
03h 4Dh # extended bytes
Questions;
(1) Please tell me the definition of the registration data.
The first data ”01h” shows Cypress, I understand.
But I don’t understand why the second and the third are “60h-17h”’S25FL064L”, and “02h-16h”’S25FL064L”
(2) Why is the third different? I understand that this represents memory’s density, so I expected these are same data.
Serial NOR
Hello Saito San,
A) The first byte is assigned by JEDEC.
The second and third are manufacturers choice. So internally our Flash Business team has decided 60h for FL-L and 02h for FL-P for second byte. Similarly for the third byte. There is no special/specific reason.
A) For the latest devices we are using 17h for 64Mb density. For older devices we used 16h. Even for 64Mb FS-S device it is 17h.
so 17h is latest convention for 64Mb density.
Krishna.
Hello Saito San,
Krishna.
Thanks!
