SIr,
We need datasheet of S25HL512TDPNHM010 for customer new project survey.
Pls kindly help to provide.
BR,
Glen
Hi Glen,
Are you a member of the SEMPER Early Access Program?
If yes, you will be able to access the datasheet for S25HL512T on this link - https://community.infineon.com/t5/Semper-Flash-Access-Program/Datasheet-Semper-Flash-with-Quad-SPI/t...
If you are not a member yet, you can register yourself here - https://infineoncommunity.com/semper-eap. Once you complete your registration, You will receive an email with further instructions. Please respond to it and then you will be provided access to the datasheet.
Regards.
Hi Glen,
Regards.
Hi Sir,
I found the datasheet from community.
Glen
