KaKi_1384211
Level 6
Level 6
100 replies posted 50 replies posted 50 questions asked
Hi Team,
Can VIO1.8V products of S25FL256S work with DDR function?
Looking at the valid combinations in the datasheet, the DDR function seems to work.
Thanks and regards,
SudheeshK
250 sign-ins First question asked 750 replies posted
Yes, S25FL256S devices with VIO = 1.8V will support DDR mode of operation. As you have already mentioned, available devices are listed under the valid combinations table.
Thanks and Regards,
Sudheesh
SudheeshK
Thanks and Regards,
Sudheesh
Hi Sudheesh-san,
Should I refer to the 80MHz specifications below for DDR specifications at that time?
Thanks and regards,
Yes, for devices with speed option DS you need to refer the 80MHz table.
Thanks and Regards,
Sudheesh
Hi Sudheesh-san,
Thank you for your prompt reply.
Thanks and regards,
