Hi, I have an XMC4500 Relax Kit from Infineon and now I am starting to program the external Flash, which is currently essentially an obsolete S25FL032P from Cypress for which Infineon doesn't bother to supply support/driver. Now Cypress is recommending to use S25FL064L. I have the option of have the chip renewed but I still do not have a driver. Does anyone here know where I can find a driver for the new (or even the old S25FL032P)
With best regards
K. Yalpani
Thank you very much... In the meantime, I installed the flash Chip on the XMC4500 Relaxkit and the example Code provided by Infineon-Dave works out of the box. So I do not need to use the driver link you provided anymore.
Hello Yalpani,
Please refer to URL for driver
https://www.cypress.com/products/serial-nor-flash-memory go to Software and Tools
Thank you
Bushra
