Nor Flash
I'm looking for code examples on how to write into S25FL127S using the SPI interface. The supplied documentation verbally explains how the Page Programming mode or 1-byte modes should work but without practical working examples I'm afraid I'm missing something important. I'm trying to erase a page, store a byte in it, the read and print the byte. No matter what I do for the writing piece, the reader always comes back with an FF. I can read serial number successfully though.
Are there any practical and working examples on how to program for S25FL127S using the SPI bus?
Thank you,
/Anna
Hello Anna,
The Low Level Driver for SPI Flash available from http://www.cypress.com/products/16mb-1gb-30v-quad-spi-fl-nor-flash-memory on the software tab will provide you with example software. If you still have issues please raise a support case using the create a support case link on www.cypress.com.
Arthur
Hello Anna,
Arthur
