Can you use the alcoholic solvent on 26KS512S?
MaKi_350451
Level 5
Level 5
Distributor - TED (Japan)
250 sign-ins First comment on KBA 10 likes given
Thank you for your support.
Can you recommned to use the alcoholic solvent on 26KS512SDPBHV020 to remove flux?
Expected due date is 9th.May
Bset Regards,
Hi Masaya Kitahora san,
Sorry for the delay in answering your query. I discussed your query with our product experts. Please find our comments below.
Cypress do not have any recommendations for solvents to remove flux. We suggest you to contact the flux supplier to know about the recommended solvent to remove flux.
Thanks and Regards,
Sudheesh
MaKi_350451
Level 5
Level 5
How about this query?
I will explain it again in janapesea.
実装工程で、フラックス洗浄の目的でアルコール系溶剤を使用する予定ですが、
IC洗浄用途のものであれば問題ないでしょうか?
MaKi_350451
Level 5
Level 5
Thank you & Regards,
Thanks and Regards,
Sudheesh
