Nor Flash Forum Discussions
Colin2
First question asked Welcome!
We have the S25FL064LABNFI010 in one of our designs, and cannot program it (previously this was done by the CEM, but they "forgot" for this batch...)
I'm attempting to use an FTDI C232HM-DDHSL-0 cable onto our board (connecting /CS, CLK, IO_0, IO_1 and GND), and the linux flashrom software to write in the supplied (and proven) .bin file. This is a copy of the setup they have, so it 'should' be possible.
I think that we may not be calling the flashrom program with the correct parameters, but (as always with linux) things don't ever actually work and the user is left to guess why not.
Has anyone used this combination and can help me work out the right settings please?
Colin
Yuvraj
250 sign-ins 50 solutions authored 100 replies posted
Thank you for contacting Infineon Technologies.
Can you please elaborate more about your query, from the description it is not clear.
What kind of error are you getting, can you share the error message you are getting.
Please provide the waveforms of the operation you are performing on FLASH.
regards,
Yuvraj
