Can I use S25FL256SAGMFI011 at 90 degrees at 3.3V when the duty cycle is less than 10%?
We apologize for the delay in our response. The maximum junction temperature of our device S25FL256SAGMFI011 is 98.1 °C.
Thanks and Regards,
Sudheesh
S25FL256SAGMFI011 is an industrial grade device (operating temperature -40°C to + 85°C). We cannot guarantee proper operation of our device outside of the operating temperature range. Can you use higher temperature grade version of this device in your application?
Please check S25FL256SAGMFV011 in the datasheet. It has operating temperature range from -40°C to + 105°C.
Thanks and Regards,
Sudheesh
Hello
Can you specify the junction temperature of: S25FL256SAGMFI011 ?
I have many unit in the field already.
Thanks and Regards,
Sudheesh
