Alternative to S29GL512P11TFCI010
HannahM5608
First question asked Welcome!
I'm writing to inquire about CYPRESS NOR Flash Parallel component (MFN : S29GL512P11TFC010).
I’m hoping you can assist me on getting the information.
Please advice whether these components are still active or discontinued ? If obsolete, kindly recommend other alternatives that has the same specification with the component accordingly
Yuvraj
250 replies posted 25 likes received 100 solutions authored
Thank you for contacting Infineon Technologies.
GL-P family is old FLASH devices you can use latest GL-S as a replacement part.
You can refer following application note which explains migration guide from GL-P to GL-S : https://www.infineon.com/dgdl/Infineon-AN98586_Migration_from_GL-N_and_GL-P_to_GL-S_Flash-Applicatio...
Thanks and Regards,
Yuvraj
Yuvraj
Thanks and Regards,
Yuvraj
