Nor Flash Forum Discussions
SaucyDinosaur
First question asked Welcome!
I'm looking for available replacements to a NOR Flash chip we are using currently as its out of stock everywhere and looking for a better preforming flash if available. We are locked into using NOR flash because of the memory interface on our DSP however we are looking for better performance in write times if possible. While stock is of course an issue with everything right now I was hoping I could get help from someone that might have insight into what is expected to be available early 2023.
Currently we are using PN: S29GL064S80TFV030. The main parameters I'm looking for in the flash chip are:16-bit parallel interfaceAt least 64MbitsWrite Cycle at least 60nsprefer BGA package, however TSOP is fine if that's the only option available.Min - Max Temp of at least  -40 to 105C
BushraH_91
Moderator 250 solutions authored First comment on blog 500 replies posted
Thank you for contacting Infineon Technology. The recommended alternate part will be S29GL128S. Please refer to url for datasheet - nfineon.com/dgdl/Infineon-1_GBIT_(128_MBYTE)_512_MBIT_(64_MBYTE)_256_MBIT_(32_MBYTE)_128_MBIT_(16_MBYTE)_3.0_V_GL-S_FLASH_MEMORY-DataSheet-v19_00-EN.pdf?fileId=8ac78c8c7d0d8da4017d0ed07ac14bd5.
For availability and pricing please contact local sales.
Thank you
Bushra
BushraH_91
Thank you
Bushra
