Nor Flash Forum Discussions
HiKu_1337496
Level 4
Level 4
5 likes given First like given First like received
Please allow me to confirm the address latch timing for the S29GL.
[A] S29GL064N90TFI020
[B] S29GL064S70TFI020
[Q1]
Section 8.2 of [A]'s datasheet states "All addresses are latched on the falling edge of CE#".
Is there any timing for address latch other than CE# falling?
I would like to confirm the address latch timing when CE# falls before the address is determined.
[Q2]
The [B]'s datasheet no longer mentions "All addresses are latched on the falling edge of CE#".
Is the timing at which the address is latched different for [B] than for [A]?
Please tell us when the address is latched.
Kumada
Yuvraj
250 sign-ins 50 solutions authored 100 replies posted
Thank you for contacting Infineon Technologies.
Q1-->Ans.)  address should be placed on the bus at least before (or equal) CE# low since the address is latched at CE# falling edge.
Q2-->Ans.) It doesn't describing a specific timing, but those GL-N and GL-S need address latching at CE# falling edge.
Hope it helps.
Yuvraj
Yuvraj
Hope it helps.
Yuvraj
KatsumasaH_16
First solution authored 10 replies posted 10 sign-ins
Hello Kumada-san and Yuvraj-san,
The timing for latching the address when reading in parallel interface products is when CE#=L or when the address changes.
Therefore, it is believed that GL-N datasheet is misstated.
Honjo
Yuvraj
Hi Honjo-San,
"The timing for latching the address when reading in parallel interface products is when CE#=falling edge or when the address changes in page read"
Hope it clarifies your doubt.
Yuvraj
KatsumasaH_16
Hello Yuvraj-san,
If the address can only be latched with CE# low edge, then continuous address access with CE#=OE#=FIXL is not possible.
P-NOR products, including the GL series, can be used in such a way, so the timing of address latching is not limited to the CE# Low edge.
Honjo
Yuvraj
Please find the below comments,
  • In case of random read or single word data read = All addresses are latched on the falling edge of CE#.
  • In case of back-to-back read (CS#=FIXL, OE#=toggle) = All addresses are latched on the falling edge of CE# or OE# rising edge (for the next back to back read).
  • and in case of Page read = All addresses are latched on the falling edge of CE# for the first data out, and then the addresses are latched at the A2-A0 transition for the next data out in the page boundary.
    Hope it helps.
Yuvraj
KatsumasaH_16
Hello
If CE#=OE#=FIXL and only the address is changed and read out, if the address can only be latched at CE# low edge, then the data cannot be read out, right?
If the address is switched from CE# low edge to within tCE, if the address can only be latched at CE# low edge, then the data at the correct address cannot be read out, right?
By the way, OE# only controls the output edge, so the address is not latched at the OE edge.
Also, where does "all addresses" mean from and to?
Honjo
