It is a matter of S29GL512S11TFIV10.
This S29GL512S11TFIV10
VCC = 3.3V
VIO = 1.8V
I plan to use it in, but according to the data sheet, the input order is
It seems that the startup is started in the order of VCC → VIO, and the startup is lowered due to the relationship of VCC ← VIO.
I have a question, but I have the following two points.
1. 1. In terms of design, I think there is no problem with the rise of VCC → VIO.
VIO (all terminal voltages follow the potential of this VIO) rises about 10 msec after booting VCC.
Is there any problem with such a sequence?
2. 2. In terms of design, I think that there is no problem with the fall of VCC ← VIO.
After starting VIO (all terminal voltages follow the potential of this VIO), about 5 msec
After that, VCC will drop.
The two main condition for power up and power down is
1) During power-up or power-down Vcc must always be greater than or equal to VIO (Vcc > Vio)
2) At any point Vio must not exceed Vcc + 200mV
So, Both your cases satisfies the conditions mentioned by me. There will not be any problem with the sequence mentioned above.
Ronak
Ronak
