Nor Flash Forum Discussions
paddyliu
5 likes given 50 sign-ins First solution authored
Dear Sir,
客户目前在选型与Altera FPGA (具体FPGA型号:5ceba4U15)搭配使用的Nor Flash,主要用于存储FPGA的配置程序, SPI通信,8引脚,256Mbit或者512Mbit,  目前我这给客户推荐的型号是:S25FS 512 S AG N F I 01 1 ,  您那能否给些建议?谢谢。
The customer is currently selecting NOR Flash for use with Altera FPGA (specific FPGA model: 5CEBA4U15), which is mainly used to store FPGA configuration program, SPI communication, 8-pin, 256Mbit or 512Mbit. Currently, the model I recommend to the client is S25FS 512 S AG N FI 01 1, could you give me some suggestions?thank you
AS_36
Our NOR Flash are not natively supported by Intel / Altera FPGA for configuration Flash. Hence, we have performed our own Flash qualification on Altera FPGA and developed following App Note: https://www.cypress.com/file/503056/download
To enable our Flash, the customer should use latest version of Altera Quartus tool suite (Revision 2020.x)
Regards.
AS_36
Regards.
