Nor Flash
JJ_II
Since AMD Flash memory spun off to Spansion and then to Cypress who is part of Infineon I am coming here with a question about how production locations stamped their country on AMD Flash Memory parts in the late 1980s. We received AMD AM9016DL/BFC parts which were supplied by Arrow Electronics back in 1986. Being Arrow only supplies parts received directly from OEMs I expect that the parts are authentic AMD parts. The marking on the bottom of each part is MALAYSIA. This marking located on the bottom is stamped in white ink and is in a slightly different position on each part. Looks like they may be hand stamped, possibly after testing or something. Was this normal for parts produced in 1980s?
BushraH_91
Moderator First comment on blog 500 replies posted 250 replies posted
Unfortunately we could not verify since this is 35 years ago during AMD time.
Thank you
Bushra
BushraH_91
Thank you for contacting Cypress Technical Support, an Infineon Technologies Company. We are currently reviewing the case and will get back to you as soon as we find the resolution.
Bushra
BushraH_91
Can you please send a picture of the AM29DL16xxx part?
Thank you
Bushra
BushraH_91
Thank you
Bushra
JJ_II
BushraH_91
Thank you for sending the picture. I will consult with marketing. This might take time as this is very old device.
Thank you
Regard,
Bushra
