dat_4767356
I want to read (SPI) the entire FRAM memory at once to avoid the overhead, is it possible?
Is there any example code for the whole memory reading, thanks!
PradiptaB_11
Hi Davis,
We do not have a specific code example for reading the entire memory. We do have a guide for SPI interface with our FRAM device with pseudo code available for reference. I suggest you go through it once as it will be helpful for you to get started. If you still face issues we will write a code example together for the requirement.
https://www.cypress.com/file/46161/download
Pradipta.
PradiptaB_11
Hi Davis,
Pradipta.
