dear cypress tech support team,
i am using cypress CM22L16 fram with my ti microcontroller 28379d.
while writing the data in the dq bits paralelly after that i am not able to read the data from the fram.
and when I put delay in writing each bit, then the data can be read from the fram.
I am using ce controlled write and ce controlled read.
i have also attached my code here.
UB and LB pins have been grounded & ZZ is pulled up high.
please tell me why i am not being able to read data from fram?
thanks
raghav
Memory Non Volatile RAM
I think you are not able to meet certain timing specifications as per the datasheet and hence facing issues which on adding delays are going away as stated by you. While doing CE controlled write and read operations please account for the timings specs as per the datasheet wave forms. Parameters like tPC, tCA, tAH, and tDS should be taken care off in the code and you should not see any errors after the corrections.
Pradipta.
Hi Raghav,
Can you please mention the full part number you are using in your setup. There is no such part as CM22l16.
Pradipta.
sorry, the correct part no is FM22L16-55-TG.
Pradipta.
