Non Volatile RAM (F-RAM & NVSRAM) Forum Discussions
Clancy
First reply posted First question asked First like given
We would like to have your help here.  About FM24CL64B-G :
Per the data sheet mentioned the second line of the top marking were BE part Rev code + lot#. But the parts arrived can ‘t match up.
We attached the top marking + datasheet marking + factory label ‘s images for your reference.FM24CL64B-G  labelFM24CL64B-G labelFM24CL64B-G markingFM24CL64B-G markingFM24CL64B-G datasheetFM24CL64B-G datasheet
PradiptaB_11
Moderator 500 replies posted 250 solutions authored 250 replies posted
Hi @Clancy ,
The marketing team checked on your query and we think there is a mismatch. We will request you to create a FA (Failure Analysis) case with us and the team will support you further from there on.
Pradipta.
PradiptaB_11
Hi @Clancy ,
We will check your query with our marketing team and provide an update on this.
Pradipta.
Clancy
Thanks for your reply. thank you.
PradiptaB_11
Hi @Clancy ,
Pradipta.
Clancy
Thank you for confirming this information and we have complete trust in Infineon. This help is enough. Failure analysis is not required for the time being. Thank you very much.
