Curious on how you can best apply F-RAM to EVs? Register for the EV Webinar here to find out how.
Non Volatile RAM (F-RAM & NVSRAM) Forum Discussions
varun
Hey guys, I see FM24C16-P(8 pin DIP) is obsolete on digikey/mouser. I found an alternative FM24C16C-G which is a 8 pin soic . I just wanted to confirm except for the package type dfiference(SOIC vs DIP), rest all is same for both the chips.
ritwicksharma
250 sign-ins 100 replies posted 50 solutions authored
Hi @varun,
Thanks for sharing the datasheet. You are correct. The major difference is the package type. But, FM24C16C-G is an obsolete part. I would suggest replacing it with FM24C16B-G.
Ritwick
ritwicksharma
Hi @varun,
As FM24C16-P is an old RAMTRON part, so we could not find its datasheet. So, could you please share the datasheet for FM24C16-P with us?
Ritwick
Hey Ritwick , thank you for the response.
here is the datsheet.
ritwicksharma
Hi @varun,
Ritwick
