Does FRAM IC FM24VN10-G, has On-chip filters to reject noise or spikes of up to 50ns (max.) coming on SCL and SDA lines Or we need to implement the filters externally?
Hi Nilesh,
Yes, the FRAM IC FM24VN10-G has internal filters (Schmitt Trigger) for noise immunity as you can see in the pin definitions.
It can tolerate a noise of upto 50 ns as also you can see the datasheet.
Thanks and Regards,
Pradipta.
