Non Volatile RAM (F-RAM & NVSRAM) Forum Discussions
Does FRAM IC FM24VN10-G, has On-chip filters to reject noise or spikes of up to 50ns (max.) coming on SCL and SDA lines Or we need to implement the filters externally?
PradiptaB_11
Hi Nilesh,
Yes, the FRAM IC FM24VN10-G has internal filters (Schmitt Trigger) for noise immunity as you can see in the pin definitions.
It can tolerate a noise of upto 50 ns as also you can see the datasheet.
Thanks and Regards,
Pradipta.
PradiptaB_11
Hi Nilesh,
Thanks and Regards,
Pradipta.
