We have developed first process computer in Romania, based on microchip technology. Your F-RAM products are the best. so after several attempts we try to use FM25V20 as a RAM memory and HDD. I write with 6.5Mhz byte by byte several times per second, to save some parameters and values (system status) but after 3 months the memory behaves strangely and not remember correctly.
please help me with this problem. what should I do... is there a refresh or other procedure...
thank you very much
Bob_Marlowe
Level 10
Level 10
I think this is a candidate for technical help by Cypress. File a technical case
Under "Support -> Technical Support -> Create a Case" you'll get a response within a couple of days, sometimes within hours.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
Hi Bob,
Thank you. I have already made MyCase no 2035887138.
 I have a big problem with that so I really need help.
Catalin
Anyone can help me, any idea. I think this is the memory capacity and I should rarely write on it.
So 10^x years are just theory.
Thank you,
Catalin Juganaru.
CY14B101 is a good alternative of FM25V20 ????
Thank you,
Catalin
