Leon_su
Distributor - Zenitron(GC)
10 questions asked 10 sign-ins 5 replies posted
Finding a replacement for MB85RS128TYPNF-GS-BCERE1 (FRAM), Does any CYPRESS parts suggest to replace it?
SudheeshK
250 sign-ins First question asked 750 replies posted
If you are looking for a device with operating temperature range - 40 C to +125 C, then the recommended replacement will be CY15B128Q-SXE. Please see the datasheet for this device attached with this response.
CY15B128Q-SXA and FM25V01A are similar devices. But, CY15B128Q-SXA is qualified for Automotive applications within temperature range –40C to +85C (Automotive-A grade).
Thanks and Regards,
Sudheesh
SudheeshK
We suggest you to use the following devices to replace MB85RS128TYPNF-GS-BCERE1 in your application. Both of them are 128Kb SPI F-RAM. Please see more details in the respective datasheets.
1. CY15B128Q: https://www.cypress.com/file/175751/download (128-Kbit (16K × 😎 Automotive Serial (SPI) F-RAM)
2. FM25V01A: https://www.cypress.com/file/139696/download (128-Kbit (16K × 😎 Serial (SPI) F-RAM)
Thanks and Regards,
Sudheesh
Leon_su
Hi Sudheesh, I found MB85RS128TYPNF-GS-BCERE1 is automotive parts with operating temperature range  - 40 C to +125 C. Is The CY15B128Q-SXE more suitable one for this operating temperature range? Or any comment for that? BTW, What is the difference between CY15B128Q-SXA and FM25V01A? Thanks, Leon
SudheeshK
Thanks and Regards,
Sudheesh
