Non Volatile RAM (F-RAM & NVSRAM)
chku_4783501
New Contributor
Need support in configuring dts and driver for fram in qspi mode.
fram part no:  CY15V104QSN-108SXI
Chetan
PradiptaB_11
Hi Chetan,
Please use the below link where you will find examples for FRAM drivers in QSPI mode under software and tools tab
https://www.cypress.com/products/excelon-fram
Pradipta.
chku_4783501
New Contributor
Hi Pradipta,
I have added FRAM driver into my linux source.
Due to mismatch in kernel version we are getting build failure(attached failure log).
kernel patch provided for 4.14.0
we are using kernel version 5.4.40
N Chetan Kumar
chku_4783501
New Contributor
Shall we have quick call related to this issue. So that we can resolve this issue at the earliest.Kindly support us ,as this issue is critical for our further development.
N Chetan Kumar
