I patched the linux-5.4.40-cy-spimem.patch to TI provided SDK.
And I modified the device tree like below,
&main_spi0 {
pinctrl-names = "default";
pinctrl-0 = <&main_spi0_pins_default>;
ti,pindir-d0-out-d1-in = <1>;
nvram@0 {
compatible = "cy-spimem", "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <40000000>;
#spi-cs-high;
#data-size = <16>;
But the spi speed is not 40Mhz as expected. Please help to point out how to set the spi speed in device tree for FRAM?
Best Regards
xixiguo
Memory F-RAM
Hi Shubham,
It's CYPRESS, CY15B104Q
xixiguo
Hi Shubham,
Thank you for this input!
I found that maybe it's because that AM64x REFCLK for spi can not be divided into 40Mhz, but it still needs to be confirmed.
xixiguo
