Is it possible to simulate access to FRAM even if FRAM is not installed by using the above?
Memory F-RAM
Hi @MAO,
Yes, you can simulate a Verilog model and check its operations even if a FRAM is not installed.
Ritwick
Hi @MAO,
Ritwick
As an additional question, can this simulation model be used for software development such as driver development?
We would also like to develop a driver to control FRAM in advance if possible.
For example, control the FRAM control IP in the FPGA from the driver, access the virtual FRAM (FM28V202A.v), write, read, etc.
If we can confirm the operation similar to using actual FRAM, we would like to utilize it for driver development.
I'm guessing that it's difficult to use it for anything other than IO timing verification, but I'd like to confirm it just in case.
Hi @MAO,
As you can confirm the operations using it, you can use it for driver development as well.
Ritwick
This is an additional question. Thank you.
I think that the actual FM28V202A has a capacity of 2Mbit, but even in the simulation model
Is it possible to simulate full area access for 2Mbit?
If you use a simulation model, please let us know if there are any restrictions on driver development.
(For example, access to a specific area can only be simulated, etc.)
Thank you
