We are using "FM25W256-G" in our design.We require power dissipation of this ic under typ,min and max conditions for thermal analysis.Also require "RθJB-Thermal resistance between Junction to Board" which is not available in the datasheet.Kindly help us to get the same asap.
ispn:37278:1:0
l1:4041:1:0
l2:4043:1:0
You can use the Pd = VDD * IDD formula to calculate power dissipation of the device. For example if typical VDD is applied to the IC the max current consumption at 1 MHz is 0.25 mA. So max power dissipation at this voltage will be
Pd = 3.3 * 0.25 = 0.825 mW
Similarly you can calculate Pd at other voltages(min, max).
You can also measure the current consumption at the supply pin and calculate power dissipation as an alternative.
Let me check for the RQJB value internally.
Pradipta.
Pradipta.
Thank you for your response Pradipta. Please let me know the Junction to Board RQJB asap.That would be of great help & please let me know why RQJB data is not mentioned in the datasheet?
Vishal.A
Hi Vishal,
We only mention the Theta Ja and Theta Jc parameter in the datasheet for the product line. That is how it was composed.
The theta Jb for the part will be 135 C/W.
Pradipta.
May i know the parts maximum Junction temperature Tj ?
The TJmax = Maximum Junction temperature. This is the maximum temperature that the device tolerates to guarantee
reliable operation. The system designer needs to ensure that TJ < TJmax to guarantee reliability.
For FRAM it is 125 C.
Pradipta.
