Non Volatile RAM (F-RAM & NVSRAM) Forum Discussions
GlenLee
First like given 10 sign-ins 5 sign-ins
Sir,
  Is possible have design guidle of Parallel  NVRAM ?
Glen
ritwicksharma
25 likes received 250 sign-ins 100 replies posted
Hi @GlenLee,
As parallel nvSRAM parts operate at lower frequencies and have a simple parallel interface, we don't have a doc specifying the guidelines.
However, for NVSRAM parts, we recommend the following:
> Length matching should be done, and the maximum difference allowed is 1 inch.
> Decoupling capacitors should be placed on power supply lines.
> A pull-up resistor should be placed on either the CE# or WE# line.
> We recommend performing signal integrity simulations using IBIS models and adding series or parallel termination resistances if required.
Ritwick
ritwicksharma
Hi @GlenLee,
Ritwick
GlenLee
Hi Ritwick,
   Could we let customer refer SRAM Board Design Guidelines  ?
   Is should be similar ?
Glen
Hi @GlenLee,
Yes, the customer can refer to that whitepaper, but please ask them to take into account the above-mentioned points.
Ritwick
