Does anyone have a communication example with CY15B116QN? I have no problem getting a stable reading from registers like Device ID, but very random luck with reading and writing. No problem with smaller-size FRAMs. Supplying 3.3V off the Atmel SAMD21 chip via standard SPI at 8MHz. Thank you.
WRITE to F-RAM works fine only once, right after the multi-byte READ command it stops writing data, and not a single subsequent iterations work.
PS: WP is connected to VDD.
Wow. Looks like decoupling caps 0.1uF close to the chip helped.
It's better to be mentioned in the spec.
Hi @mikkadim,
We recommend keeping the decoupling capacitor as close as possible to the device pin.
Could you please let me know if the issue is completely resolved?
Ritwick
Hi Ritwick,
I would recommend having decoupling capacitors for this chip now too, but I saw not a single word about capacitors in a datasheet.
