asbh_3244391
Could you please provide the IBIS model for CY15B102N-ZS60XAT.
We planning replacing FM28V202A with CY15B102N-ZS60XAT in our design. Is the performance  characteristics of both the devices are same?
PradiptaB_11
Please use the attached IBIS model. The IBIS model of FM28V202A is applicable for CY15B102N-ZS60XAT. The difference between the parts is FM28V202A is qualified for Industrial and CY15B102N is qualified for Auto-A grade. Hence IBIS model of FM28V202A can be used for CY15B102N part. The operating temperature rating of both the parts is -40C to +85C. I have attached the model.
Both parts are identical in performance. The only difference is the qualification as explained above.
Pradipta.
PradiptaB_11
Pradipta.
