HI,
I am using CY15B064Q-SXE IC as it suits my requirement.
In the product spec it was written that minimum operating temperature is -40 deg.
But in datasheet it is mentioned that, the operating temperature range when powered up is (-50 deg).
Which temperature should i consider.
What is the difference between them.
Thanks & Regards
Naresh
Memory F-RAM
Hi @nareshreddy ,
The minimum operating range is -40 C where the device will exhibit all the datasheet listed performance in terms of DC and AC specs. We do not recommend using the device below this temperature.
-55 C is the max rating for the ambient temperature. Exceeding maximum ratings may shorten the useful life of the
device. Also below -40 C you may not see datasheet listed performance. The AC specs for the part may exceed their mentioned values in the datasheet. Hence the datasheet only mentions -40 C as the minimum operating temperature.
Pradipta.
