Non Volatile RAM (F-RAM & NVSRAM) Forum Discussions
WaCh_4680201
Dear Cypress team,
I am looking for linux driver for this device.  Is there any driver compatible for this?
I have kernel 4.9.140 and ARM platform.
Walter
GirijaC
50 sign-ins 25 sign-ins 10 solutions authored
Hi Walter,
I got a response from our internal team. Currently, we do not have an explicit nvSRAM driver for Linux  However, we recommend use either the
      Linux SPI EEPROM driver under: drivers\misc\eeprom\at25.c
or the
     Linux SPI Flash drivers under: drivers\mtd\spi-nor\spi-nor.c + drivers\mtd\devices\m25p80.c
Both drivers are using device ID based probing that needs to be disabled and hard wired to the appropriate device entry (density, capabilities, …). Basic READ and WRITE functionality should work in this case with the above drivers, but note that there is no support for special NV instructions such as STORE or RECALL.
Girija
GirijaC
Hi Walter,
Please let me know the exact nvSRAM part number which you are planning to use. This will help us to check the availability of the driver.
Girija
Hi Girija,
The exact nvSRAM part number is: 170120 - Cypress CY14B101Q2LHXI
Walter
GirijaC
Hi Walter,
Thanks for providing the part number. I will check with our internal team and let you know if we can support your request.
Girija
GirijaC
Hi Walter,
or the
Girija
Thanks Girija.
