CY14B101LA-SP25XI external pull-up resistor on HSBn
lasa_783466
  1. AN6023 speaks about a pull-up to VCAP, AN43380 speaks about a pull-up to VCC, so ?
  2. AN43380 recommendes HSBn configuration with an external pull-up resistor between 5.6 kΩ and 10 kΩ to Vcc.
Our design is with HSBn pulled up to Vcc with 4K7, and interfaced with a single gate 74LVC1G14. Is it correct ?
PradiptaB_11
The 4.7 Kohm resistance will work correctly. You can go ahead with this design.
Pradipta.
PradiptaB_11
Pradipta.
