Jul 10, 2018
09:51 PM
Jul 10, 2018
09:51 PM
Could you provide AC Switching Characteristics of I2C standard mode (100KHz) of FM24V01A?
Datasheet shows the Fast mode plus(1MHz) and the Hs mode(3.4MHz) only.
I believe that it is same as I2C bus specification published by NXP.
Customer want to confirm some parameters which are defined as max value at the standard mode.
Naoaki Morimoto
Labels
11:31 PM
Jul 15, 2018
11:31 PM
Hi Naoaki-san,
Yes, you are correct the specs are same as I2C bus specification by NXP. I am attaching the user guide by NXP which has the specs defined in it. Kindly refer to it, and let us know if you have any further query.
https://www.nxp.com/docs/en/user-guide/UM10204.pdf
Thanks and Regards,
Pradipta.
