关于 FM28V202A-TG 的疑问
公告
大中华汽车电子生态圈社区并入开发者社区- 更多资讯点击此
misu_4842326
First question asked First reply posted
FM28V202A-TG
大家好,我是个维修工程师,对这颗芯片不太了解,我想知道的是,这颗芯片是不是一定要编程之后才可以使用,如果是这样的话,用什么型号的编程器可以读取并写入?
0 点赞
1 解答
PradiptaB_11
You do not need to program the memory chip in any way or configure it. You can check the device datasheet as well to confirm this. You can connect the memory to any controller and start using the device.
Pradipta.
在原帖中查看解决方案
0 点赞
3 回复数
PradiptaB_11
Pradipta.
0 点赞
你好,我还有一个疑问,RAMTRON的FM28V202-TG可不可以代用这颗芯片?,期待你的回复!
0 点赞
PradiptaB_11
The FM28V202 is an older version and the FM28V202A is a newer part with a die revision. These parts will be same performance wise so you can use the older version as well.
Pradipta.
0 点赞
