I have a problem with flashing the IMC102.
the firmware and the parameters can be flashed successfully.
then I want to download the script and I get the following error message :
Programming Script file failed ! Mode is not in appciation !
In the wizard everything is configured correctly also the script is enabled and successful. The connection is immediately gone after flashing the script and the chip can no longer be connected to the designer.
Hi @Abc1,
MCE Designer needs UART0 as MCE UART to remain connected with the iMOTION Device.
Can you please let us know if UART0 is being initialized and used in the script?
Krupashankar
Hi @Abc1,
Krupashankar
