Jan 02, 2023
06:41 PM
Jan 02, 2023
06:41 PM
Jan 02, 2023
08:30 PM
Jan 02, 2023
08:30 PM
Hi @User19250
We have submitted this issue to the internal department. Once the problem is solved, you will be notified.
Jan 12, 2023
08:47 PM
Jan 12, 2023
08:47 PM
Hi @User19250
As a work around, you can download the SDpack from the online location (https://itools.infineon.com/solutiondesigner/imotion/packages/) and install it in the package manager from SDpack file.
Ram
Jan 13, 2023
12:10 AM
Jan 13, 2023
12:10 AM
Jan 25, 2023
11:22 AM
Jan 25, 2023
11:22 AM
I had the same issue. Did you get it solved? I need to test the firmware update as soon as possible so as to check if it solves a problem I was having in the previous version
