i just got motoin2go board, install MCEDesigner but when i open file IMC101T_V1.02.20_iMOTION2go.irc it give error
product mismatch. i try another ver MCEDesigner ver2.1.2.0 but it give an other error unexpected keyword Tune_lock_mode.
Can someone help me out what i am doing wrong.
Rgds
Hi @sohail,
Please download the latest iMotion software package- iMOTION2Go Software Package v1.0
Download the latest MCE Designer version - MCEDesigner v2.3.1
Please program the latest firmware( IMC101T-T038_A_V1.02.20) and update the register map(iMOTION2go190904-Neweco2_IMC101T.map) from the iMotion2G0 Software package
You can follow the below steps to update the register map:
File->Import Register Map-> Path of iMOTION2go190904-Neweco2_IMC101T.map file
Please let us know if this solves the issue
Krupashankar
Hi @sohail,
Krupashankar
Thanks its solved, I am new user just learning motor control. One more question as per my understanding if I want to write my own scripts. i.e. motor run for 2 min than stop & again run with different speed. it is possible but where can write scripts & compile it. I read motion™ Motion Control Engine Software Reference Manual.
which IDE I have to use for writing program & compile it any help on this topic.
Hi @sohail,
Yes, It is possible using the script. Please refer to How to Use iMOTION™ Script Language
The script can be written and compiled using MCE Wizard.
Krupashankar
