er_misha
First like received First question asked Welcome!
1)There is no option to update iMotion Solution Designer, In the news feed it shows updates for SD package
2) No option for induction motor driver in the SD package. can you please advise how to add or find induction motor in the list.
3) Is it possible to use MCE & PFC only in IMC302 standalone without coding for the ARM cortex CPU, please advise tutorial or reference document where it can be found if possible
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @er_misha,
1) Please install the latest SD package 5.1.18 available as shown in below image.
2) iMOTION supports only open-loop control of Induction motor and following appnote : Induction motor control by iMOTION™ describes induction motor control with MCE Wizard/MCE Designer tool. Same can be implemented in iSD.
3) Yes, In IMC302 device the MCE/PFC core ( T- Core) can be independently programmed using iSD and can be controlled without using A-core.
Krupashankar
Krupashankar
Hi @er_misha,
Krupashankar
